I have working against a number of API’s today in 360 field, the following API’s were working this morning and no longer appear to be functional… (I haven’t made any changes to my application). I receive a 404 error code when I access these locations with a web browser or my application
The following API is working both in my application and in a web browser so I know some of the service is accessible.
Sent an email to support and they directed me here... hopefully this is the right forum...
Please advise?
Solved by mikako_harada. Go to Solution.
Could you check if your verbs (GET, POST, etc.) are the same as in the document?
http://forums.autodesk.com/t5/bim-360-api-forum/field-api-enforced-route-verbs/td-p/6719836
Thank you. Yes, I was using a get instead of a post... It seems to be working now. Interestingly enough - it was working for two days before...
