Is it possible to create shared view and shared folder using BIM glue API?
Although as I remember, the API document website contains an endpoint with has two parameters (is_global and is_folder ), which looks like the way to create shared & folder, I also noticed a comment my colleague Mikako mentioned in the other thread:
Property access, creating views and marekups are legacy wishes that people are asking.
So, I am afraid the ability of creating view has not been exposed yet. I will double check.
After discussing with our engineer team.,I also gave it a test.The API supports creating viewpoint, and view folder.
for folder or specific view: is_folder and is_global are required parameters
for specific view: is_folder, is_global and view_object are required parameters
These below are the post body I tested with:
Folder:
company_id=XXXXX& api_key=XXXXXXXXXXXXXXX& auth_token=XXXXXXXXXXX& model_id=XXXXXXXXX& view_name=XiaodongViewFolder& is_folder=1& is_global=0& timestamp=XXXXXXXX& sig=XXXXXXXXXXXXXXXXXX
View:
company_id=XXXXX& api_key=XXXXXXXXXXXXXXX& auth_token=XXXXXXXXXXX& model_id=XXXXXXXXX& view_name=XiaodongOneView& is_folder=0& is_global=1& view_object={"Type":"AutodeskCommonCamera", "Projection":"Perspective", "Version":1, "VerticalExtent":321.459933, "HorizontalExtent":472.457626, "TargetDistance":278.392468, "UnitsToMetersScaleFactor":0.3048, "WorldUpDirection":[0,0,1], "WorldFrontDirection":[0,1,0], "WorldRightDirection":[1,0,0], "Position":[164.83782,-217.078747,204.330387], "ViewDirection":[-0.57735,0.57735,-0.57735], "UpDirection":[-0.408248,0.408248,0.816497], "NearDistance":0, "NearDistanceType":"Auto", "FarDistance":1, "FarDistanceType":"Auto", "UpOffset":0, "RightOffset":0, "ImageFit":"Vertical", "HorizontalScale":1, "ApertureDiameter":0, "ShutterSpeed":0}& timestamp=XXXXXXXX& sig=XXXXXXXXXXXXXXXXXX
Hope this helps.
Hi Xiaodong,
Can we create a markups using BIM Glue API, if it is possible from Navisworks how can get information required for Markups, also let me know the sample API snippet for creating the Markups as shown above for Views
