AutoSketch
paul.wacko
Message 11 of 28 (4,584 Views)
Re: Windows 7 vs Autosketch
02-28-2011 05:20 AM in reply to: Frodad
Turn the UAC off from the getting started menu.
User Account Control.
Then install your program
Paul
Paul Jackson
Western Australia
http://www.resolv.com.au
New Member
billjest
Message 12 of 28 (3,960 Views)
09-30-2011 11:52 AM in reply to: Frodad
Try,
Setting up virtual XP. on Windows 7 (I'm using Ultimate)
Then go here.
http://boardreader.com/thread/Windows_7_Autodesk_Discussion_Groups_bhwqcX1mfzj.html
I did what he suggests for Auto Sketch 2.1 and it WORKED. Amazed.
Finally I can dump that old XP machine. I have now got access to 15 years of autosketch drawings.
Member
RHTE
Message 13 of 28 (3,954 Views)
09-30-2011 11:58 AM in reply to: billjest
This has been the only solution Ive been using and Billjest is correct, this works well.
New Member
rwsql
Message 14 of 28 (3,722 Views)
12-09-2011 08:08 PM in reply to: Frodad
Good Folk,
Do any of the solutions mentioned so far (before 12/9/2011)
on this topic work with windows 7 home premium?
Has Autodesk indicated whether a version of Autosketch
will be available that will work with Window 7 without the XP
virtual machine?
Thanks for any help - I sure can use it.
/Robert
StevenMac
Message 15 of 28 (3,700 Views)
12-12-2011 02:04 AM in reply to: rwsql
Robert I use 'sketch 10 and Win7 (32 bit) at home, and 'sketch 10 and Win7 (64 bit) at work.
The program runs just fine.
Active Member
gregmacp
Message 16 of 28 (3,275 Views)
04-09-2012 06:36 PM in reply to: paul.wacko
I had to go the virtual  machine route (XP running on the machine as well as Win7) as well. AS ran fine at first in Win7 but then kept freezing and I couldn't do a "Save As." Autodesk  if not commenting on whether they will be offering an fix to AS10 or a new version that will allow the program to run in Win7. Very annoying as I cannot print AS files except to Acrobat.
Greg
New Member
ianhobba
Message 17 of 28 (3,013 Views)
07-17-2012 11:40 PM in reply to: Frodad
My solution to the problem was to install Autosketch (my version is 6.1) onto a memory stick, on a Windows XP PC, and use it from the memory stick on my Windows 7 Laptop, apart from failing to register on the computer it works perfectly well (as far as I can tell).
The next step was to copy the Autosketch Folder from the memory stick to Program files on my C: drive, still have the 'failed to Register' error message, but when I close the message, the program still works with no groans, I haven't come across any problems yet anyway.
The final step will be finding how to use Regedit to register Autosketch on the laptop. Maybe the problem lies in the Installing program 'setup.exe', perhaps it is the cause of problems in setting up Autosketch on Windows 7. I'm no computer guru, otherwise I may have been able to load it on the way others have been successful.
Thanks for the useful information and the space.
StevenMac
Message 18 of 28 (3,008 Views)
07-18-2012 04:27 PM in reply to: ianhobba
There's a program by microsoft (I think it was made by another company that was taken over/sold to microsoft) called Fixit. Free to download and it may help install/uninstall issues on Win7
http://support.microsoft.com/mats/Program_Install_and_Uninstall/
New Member
ianhobba
Message 19 of 28 (3,004 Views)
07-18-2012 06:58 PM in reply to: paul.wacko
Thank you StevenMac, a good suggestion, but because I haven't installed the software on the comnputer by way of the setup.exe, it isn't in the registry, so an error in the registry can't be found by fixit. Never mind, Autosketch is working on my laptop, all I have to do is close an error message on the screen and start drawing! Thanks again.
tom
New Member
tom
Message 20 of 28 (2,250 Views)
12-19-2012 10:25 AM in reply to: Frodad
Regardless of what Autodesk says, Autosketch 10 installs and runs well on a 64bit Dell desktop.
