David, there is a patch for AutoSketch 2.1 that will correct this for
you located here:
http://support.autodesk.com/getDoc.asp?id=DL135184
What's happening is that your version is using SmartCursor to display
the function for the toolbar buttons at the top of the drawing screen.
Without the patch that corrected this (originally for NT), the program
will halt with the GPF error message you found. Windows 98 caused the
program to crash just like Windows NT used to.
Without the patch installed, the only other way to turn off SmartCursor
so you won't get the GPF is to start Sketch, avoid the buttons and then
exit using Alt+F4. Next locate and open sketch.ini and set
"SmartCursor=1" to "SmartCursor=0". Save as text only and start Sketch
again.
Without first closing Sketch for the first time, the sketch.ini doesn't
get created.
davidhetzler wrote:
> I have been a dedicated 2.1 user for many years and want to continue
> to use it on my new computer which has Windows 98 as it's operating
> system. The program installed fine and I can open the program but
> after no more than 30 seconds of moving the arrow around I always get
> an error message:
> SKETCH caused a general protection fault
> in module SKETCH.EXE at 0090:000076fc.
> Registers:
> EAX=17afffff CS=52c7 EIP=000076fc EFLGS=00000286
> EBX=0000008e SS=30c7 ESP=0000d610 EBP=0000d642
> ECX=000005dc DS=0000 ESI=000000dd FS=0000
> EDX=1f6e0000 ES=16d7 EDI=00000210 GS=0177
> Bytes at CS:EIP:
> 89 36 82 44 8b 46 e4 a3 9e 0c 83 3e 86 44 00 75
> Stack dump:
> d6720001 e28c3d5f 00000000 002403e5 000017a7 0006d652 000017a7
> 0200001d 000030c7 63cf240a 63cf23e6 63cf23e6 d66730c7 17c71025
> 001d00de 02000000
> Does anybody have an idea of how to fix this,
> Thanks
> David Hetzler
Bob Felton
Autodesk Product Support, Americas
WW Support and Services, Autodesk
Discussion Q & A: <>>
