AutoSketch
V7 Patch does not work in German version?
2 REPLIES 2
604 Views, 2 Replies
After downloading and installing the Sx2.dll I can't startup the program
anymore. Error: "Der Prozedureinsprungpunkt
"?ToolSelected@SxBar_Tool@@MAEXHI@Z" wurde in der DLL "Sx2.dll" nicht
gefunden".
Anybody knows this problem? Please help! I am not amused about that after
waiting about two years for this patch.
Jan
2 REPLIES 2
I had exactly the same problem in the English version. Had to uninstall and
reinstall. See my other post.
Bri
"Jan Karsch" wrote in message
news:64860598B436B11C1BCEDE219A590D65@in.WebX.maYIadrTaRb...
> gefunden".
> Jan
Jan, assuming you overwrote your previous version of sx2.dll when you applied
the patch, the best way to return to it so that Sketch will start is to
uninstall and reinstall without any antivirus running in memory.
By the way, have you seen the TS66300 that discusses the sx2.dll issue?
It's located here: http://support.autodesk.com/getDoc.asp?id=TS66300
I have created a case number (CID 756086) tracking your experience with the
sx2.dll patch with the localized versions of AutoSketch and will report back
to you and this newsgroup what the best resolution will be.
> gefunden".
> Jan
Note: English translation for the above error message:
The point of procedure re-entry point "?ToolSelected@SxBar_Tool@@MAEXHI@Z "
was not found in the DLL " Sx2.dll " ".
Bob Felton
Autodesk Product Support, Americas
WW Support and Services, Autodesk
Discussion Q & A: <>
