AutoSketch
Using types of lines
2 REPLIES 2
Rebyeby1
359 Views, 2 Replies
I just installed Autosketch 10 today, after haviing used various versions for over 10 years. My current problem is changing from a dotted line back to regular straight lines, the ones that come up with new files. I click on the line property I want, but when I go to draw a line, the dotted line in all I get, and it is extremely annoying. Help, please!!!
Rebyeby1
2 REPLIES 2
Fred9002
in reply to: Rebyeby1
Your description does not match normal AS behavior. Of course there may a malfunction, but also possibly some confusion. The two most common methods to do what you are saying would be
select "solid line' from the menu and draw the line.
select an already-drawn dotted line, and then select solid line from the menu.
Is this what you tried?
StevenMac
Draw some lines, save the file, and upload it so we can have a look please
