i am doing a drawing in autosketch it is a detailed drawing as i am trim joining all the lines one section that is put together with endpoint snaps will not join as i was zooming in out i noticed a pink line that came in diagonally to the section i was joining as i zoom out to delete it it disappeared. when i zoomed in you could clearly see it it would not let me click on it or select it. now it will not reappear but the two lines you can see will not join i move them around in an out further apart no matter what i do they will not trim join. any suggestions???
there must be a line or command there i cant see how do i find it and get rid of it so it will trim join???
