Bob,
Thank you very much.
Now that you explained it to me how it should be done
this remaining BIG problem has been resolved.
It seems so simple now and I feel like an idiot.
The solution will be named, filed and clicked under
"Bob's Polygon" for easy future visual reference as I already
have Paul's Roof, Harvey's 6.01 Patch, John N's Symbol Change,
Len's Line Thickness, John E's Printer, Alm's Character Map,
Marina's NoNo's etc.
Tried yesterday to replace a 15 year old twin garden hose
connection. Used WD40 and liquid wrench and it would not budge.
Beside you being an Autodesk Pro, do you handle Plumbing Problems
too?
Gerhard 😉
"Bob Felton (Autodesk Support)" wrote:
> Gerhard, I recreated your enclosed boundary in Sketch 6.1 and was able to
> Edit/Trim/Join and by holding the Ctrl key, click on one of the end arcs and then
> the solid fill showed up ( I had first selected the 3-point arc, two end arcs and
> bottom polyline and selected solid pattern from the properties toolbar).
> Make sure you snap the end arcs to the ends of the bottom polyline and also snap
> the 3-point arc to the end arcs. If there's an opening, it won't fill.
> Gerhard Selzer wrote:
> > Paul,
> > Thanks. Hatch problem resolved.
> > Without appearing greedy, may I appeal to your infinite wisdom
> > to have an answer for my Solid Fill problem?
> > The landscaped island [for lack of imagination green fill]
> > consists of two semi circles at each end, a straight line at the
> > bottom and a 3 Point Arc at the top.
> > Since no attachments are permitted, (___^^^___) this is my simple
> > Rube Goldberg visual presentation under the circumstances and
> > where ^^^ represents the arc. All of course are polylines.
> > Can one join them through Trim Join, Snap or Translate command
> > to get a polygon to be filled or is the Irregular Polygon choice
> > the only option available? I am trying to avoid to have to go
> > tediously around each semi circle and the arc in 15cm or less
> > intervals to simulate the curves for smooth instead of ragged fill
> > appearance for printout at a larger scale.
> > Since there many similar different shapes on the site plan, I would
> > appreciate any suggestion you might have to reduce this lengthy,
> > unsatisfactory process I am using now.
> > Gerhard
> Bob Felton
> Autodesk Product Support, Platform Technology Group
