I HAVE SUTOSKETCH 9
WHEN I GO TO EDIT-TRANSFORM-TRANSLATE: I GET IT T O MOVE WHERE I WANT IT, HOWEVER THE ORIGINAL PART OF THE DRAWING IS STILL SHOWING. WHEN I AM MOVING IT AN INCH AWAY IT IS VERY DIFICULT THE MANUALLY DELETE IT.
IT USED TO WORK FINE
THANK YOU
HOWARD
Look on the left had side of your EDIT BAR and you will find a tick in a box.
Remove it and all will be well.
When you select transform a tickbox does indeed show up just below the layers drop-down in the property toolbar, at least that's where it appears on my three 'puters. Not a new problem, my oldest version is AS6 and I also work with v10. Same tickbox, same place, though I will admit I have not worked with v9. When you select transform look towards the upper left-hand corner of the AS desktop. Should be there. Make sure it is not ticked. Move entities 'til you heart's content. Nice.
I am trying to translation the text into other language, I would prefer to download the English text into a file, then add the translation, then upload the file into DWG so that both English and other language would appear in the DWG. How do I do this? Thanks for the help!!!
