Smoke wrote:
> Greetings troops,
> I have created my own template for my drawings. It's size was about 40k.
> However, I made a small logo to place in the title block. It's size was 8k.
> I copied and pasted into my template, and the template's size jumped to
> 415k!
> What is the proper procedure for adding your logo to title blocks? Is
> there a file format it should be converted to first? How can a half inch
> logo become 415k? A half a meg blank drawing is not acceptable. If it
> matters, the little logo was created in a program called Xara. Also have
> CorelDraw, but have not tried bringing in a logo from it. I am using R7,
> which I really don't understand lack of import capability. Also have old 2.1
> version at work, that had import feature. We use SolidWorks mainly, but that
> old 2.1 still is handy for a quick sketch. Maybe some insight on the
> paste/paste special in R7 would be useful.
> Thanks for any thoughts. Have a good weekend.
> Mike
If you have AutoCAD, try opening the logo in it, exploding it, purge and save.
reopen in AutoSketch.
AutoSketch SKF format is fat, much fatter than say a DWG file. I found that an
SKF file can be 4 to 5 times the size of a DWG (or the old Drafix CAD format).
Another option would be to save the file as DWG format and then reopen the DWG
file with AutoSketch and see if skinnies up the file.
Len Rafuse
Vision Engineering
