Len has missed the point....again....!!!
All my Title Block are 'attributed' and some (but not all) attributes
created in AutoCAD and then opened in AutoSketch/QuickCAD will not translate
correctly and will need to be "re-formulated/re-created". In AutoSketch,
this can be achieved via (Menu) "Database".
AutoSketch/QuickCAD vs AutoCAD are not 100% compatible. Sad but true.
Quite frankly, I would steer clear of any vendors using
AutoSketch/QuickCAD.....it will become messy....as you have already
discovered.
Ric Norris.
http://users.bigpond.net.au/cavedrawings
"milesk" wrote in message
news:32577451.1091470230161.JavaMail.jive@jiveforum2...
> I sent a blank drawing format (Autocad ver 2000) with an attributed
titleblock to a vendor who was supposed to create some simple tag drawings
using Autosketch (ver 8). He tells me that he does not have any command to
fill in these attributes and had to explode the block and create text
entities. I don't know anything about Autosketch so I would like to know if
he's correct, or whether he just isn't fully aware of his software
capabilities. If necessary I could e-mail someone the titleblock to
experiment with.
> Thank,
> Kim Miles
