AutoSketch
AutoSketch
Active Member
Xfieldok
Message 1 of 5 (1,621 Views)
Spline and Fitted Curves pen width
1621 Views, 4 Replies
01-21-2011 06:54 AM
I have been happily using spline  and fitted curves with no problems.  Suddenly, they are not responding to a change of line width, can anyone explain what I am doing wrong?
StevenMac
Message 2 of 5 (1,618 Views)
Re: Spline and Fitted Curves pen width
01-21-2011 01:13 PM in reply to: Xfieldok
Can you attach the drawing so we can have a look? You may have to rename the file extension to .doc or .bak for the forum to accept it.
Active Member
Xfieldok
Message 3 of 5 (1,607 Views)
01-21-2011 11:28 PM in reply to: StevenMac
Thank you Stevenmac.  Attached is spline.doc which was renamed from spline.7z.
The item is in green.  Have tried every which way to change the width to no avail.  I cut and pasted this into another document and it appeared to work, but not in this one.  Any advice gratefully received.
StevenMac
Message 4 of 5 (1,603 Views)
01-22-2011 02:20 AM in reply to: Xfieldok
Thank you for the upload.
You might not be aware that your 'curve' is actually a multi-segment polyline, and not a spline or fitted line? It only looks curved because it's made up of 30+ straight lines (double left-click it and see for yourself).
Delete it and draw it again with the right tool if need be... however that still leaves the puzzle of why entering in a new line thickness doesn't actually change the polyline thickness.
Are you aware your drawing is set to a precision of "1. mm". If you want a line 0.05mm thick you need to go into:
TOOLS > DRAWING OPTIONS > UNITS > LENGTH > DECIMAL PRECISION > change from 1. to 0.01
Cheers
Active Member
Xfieldok
Message 5 of 5 (1,581 Views)
01-24-2011 07:18 AM in reply to: StevenMac
Thank you StevenMac.  It was not quite the solution, I am still not sure what is, but you sent me on the right track and I got round it.
Looking forward to Paul releasing his book.......
