AutoSketch
Spline and Fitted Curves pen width
4 REPLIES 4
Xfieldok
2300 Views, 4 Replies
I have been happily using spline  and fitted curves with no problems.  Suddenly, they are not responding to a change of line width, can anyone explain what I am doing wrong?
4 REPLIES 4
StevenMac
in reply to: Xfieldok
Can you attach the drawing so we can have a look? You may have to rename the file extension to .doc or .bak for the forum to accept it.
Xfieldok
in reply to: StevenMac
Thank you Stevenmac.  Attached is spline.doc which was renamed from spline.7z.
The item is in green.  Have tried every which way to change the width to no avail.  I cut and pasted this into another document and it appeared to work, but not in this one.  Any advice gratefully received.
StevenMac
Thank you for the upload.
You might not be aware that your 'curve' is actually a multi-segment polyline, and not a spline or fitted line? It only looks curved because it's made up of 30+ straight lines (double left-click it and see for yourself).
Delete it and draw it again with the right tool if need be... however that still leaves the puzzle of why entering in a new line thickness doesn't actually change the polyline thickness.
Are you aware your drawing is set to a precision of "1. mm". If you want a line 0.05mm thick you need to go into:
TOOLS > DRAWING OPTIONS > UNITS > LENGTH > DECIMAL PRECISION > change from 1. to 0.01
Cheers
Xfieldok
Thank you StevenMac.  It was not quite the solution, I am still not sure what is, but you sent me on the right track and I got round it.
Looking forward to Paul releasing his book.......
