Don't yell, Brian. Just spotted this.
I don't believe that there's a converter for AS R5 on the original CD.
But here's what you can do for R6, which you probably got from the
knowledge base:
On the AS6 CD is a 21fc file converter program that will load version
2.1 on your system. It has been stripped to just be a converter so all
you can
do is to open the older version files in it and then save out as a 2.1
skd
format which Autosketch 6 will then open.
Do a file open and set the files of type to skd in Autosketch 6 find the
converted drawing and Autosketch should open it.
If you want to send me the file, maybe I can open it using the AS R6 CD,
convert it for you and send it back.
Failing that, it couldn't hurt to locate an R6 CD and install it. You
can check eBay. That's all I can really say about that.
B Boardman wrote:
> I recently posted a query about a problem opening SKD files in
> AutosketchV5.01. Having had no replies I delved a bit deeper and found a
> reference to this in the knowledge base. But this referred to the problem
> in version 6 and mentions a patch that can be downloaded. So my new
> question is can this be applied to Version5 or do I need to update and
> assume that later versions have addressed the problem. It was something to
> do with fonts.
> BryanB
