I set the decimal precision to 0.001
I need to scale on the y-axis only, to scale an object 30x42.857 to 30x48, a factor of 1.120 on the y-scale.
I selected the grouped object and dimensions. (The object is made up of arcs and lines.
I have tried to scale by dragging down the y-axis, holding down shift to unconstrain the x- and y-scale (described in Help), and the y-scale only rescales, but when I release the button, the x-scale rescales, also.
I have tried using Transform,Scale, unchecking the Scaling Factor check box, used (1.000,.1.200) to scale y-axis only, but I get the same result, with the x-scale affected, also.
When I try the same on a simple box, the y-scale rescales, leaving the x-scale unaffected.
What do I need to do?
Thanks.
Greg
