AutoSketch
Recently Purchased a HP computer preloaded with Windows7.
1 REPLY 1
MFiler
394 Views, 1 Reply
I would like to continue using my AutoSketch 6.0 (AS6) program to do my work. The computer says that AS6 is not compatible with Windows 7. I have tried to load it using the program version feature, but it does not work. Autodesk says it is not compatible, and I have to use a different OS in order to use my program. I have loaded it into my HP netbook with Windows 7 starter os, but it is having some functionality issues. is there a way to load this version and make it work? I would appreciate any guidance offered to solve this problem.
1 REPLY 1
StevenMac
in reply to: MFiler
Any particular reason you don't want to go with 10?
$250
http://store.autodesk.com/store/adsk/pd/productID.108927600
