We need to know what OS you are running on your machine. You may need to
copy the contents from the cd to a install folder on your hardrive and
then go into the safe mode and run the settup.exe from the new install
folder. There are some file extensions that need to be turned on and
depending on the OS it is done in different ways.
Stahlbauer wrote:
> Starting the installation of Autosketch R5 from CD-ROM, I received the
> error-message: "Setup is unable to find _setup.dll,... error 103". How
> to manage this problem?
> Thanks for help, Tomas.
