AutoSketch
Problems with the Fill Option
1 REPLY 1
LineDrawer
387 Views, 1 Reply
I am using the Fill Hatch command to fill a circle and changing that into a solid fill using entities.  My problem is that the solid fill is overlapping the line I used to draw the object.  Is there a way to fill the object and have the line on the edge show?  Thanks in advance for any advice.
I linked the picture, and it doesn't have a clear line.  If I intensify the line around the fill, you can see the results on the right.  I just want to see a clear border on the object.
Tags (1)
1 REPLY 1
StevenMac
in reply to: LineDrawer
There's a toolbar called "arrange", which has a button for "move to front" and "move to back".
After a while sketch will begin to forget what's supposed to be where, then you'll need to practice this method:
-> Click either the outline object or the fill object to highlight it
-> go to the layers dropdown bar and re-click the layer it's sitting on
-> use the arrange buttons to confirm where this shape should sit
