AutoSketch
Problems opening files
2 REPLIES 2
371 Views, 2 Replies
I have had this problem happen more than once. I recieved an autocad file and saved it as an autosketch file. I then make changes to the drawing and continued to save it as an autosketch file. Today, I try to open the file and I get a message that says "can't find row 49 in table 9". I can't find a way to clear this message and I must use the windows end task button to close down autosketch. Does anyone have any suggestions on what I can do to open the file?
Thank you.
2 REPLIES 2
bauguss wrote:
> I have had this problem happen more than once. I received an autocad
> Thank you.
Click Ok every time it comes up. Sometimes you need to do this 10 to 30
times before it opens.
Others here can tell you what that tow error is.
I usually get that error trying to save after I have deleted several layers
Len Rafuse
Vision Engineering
This same question comes up from time to time. Paul has answered it in
the past. I should remember? I think it has to do with text or a
particular TT font in the original. There's a simple fix.
Someone answer this!
> Thank you.
