AutoSketch
AutoSketch
Active Member
0 Kudos
Post 1 of 5
Problem to save some files in DXF
638 Views, 4 Replies
04-18-2013 03:38 AM
Today i had tvelve (12) drawings to convert from .skf-format to .dxf-format (AtoCad2007.dxf)
Ten files was succesfully saved but two files failed.
Every fila are named as SR1201-2xx (-270, -271, -272 ....)
All files are created during the last two montth on the sam computer (Windows 7, 64bit)
I run AutoSketch 10.
A messagebox pops up saying "Error: Failed to save file".
I can't see any differens for these to files.
I also tryed to save sem in .dwg-format with the same negative result.
Have anyone a tip?
*Expert Elite*
263 Kudos
Post 2 of 5
Re: Problem to save some files in DXF
04-18-2013 04:43 AM in reply to: salren
Hello
Mysterious !
Maybe I could try with my AutoSketch v9 to generate DWG or DXF !
If you can give us the 2 SKFs files (ZIP format please)...
But I don't konw if my AK v9 can load yours AK v10 drawings ?
Bye, Pat
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
*Expert Elite*
1,605 Kudos
Post 3 of 5
04-18-2013 05:04 AM in reply to: salren
Autosketch forum may be of more help:
http://forums.autodesk.com/t5/AutoSketch/bd-p/107
Usually, when a translation fails, it means there is either an error or an unknown object that does not have a DXF or DWG code equivalent.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
0 Kudos
Post 4 of 5
04-18-2013 05:04 AM in reply to: braudpat
Hello Pat
No you are right you can?t open Ver10-files on a Ver09 program.
I think its a window-system-problem but i dont know how.
Thanks for your interest
Bye, Hans
*Saltsj? Reningsteknik AB*
1 Kudo
Post 5 of 5
04-19-2013 06:05 AM in reply to: salren
Can you .ZIP the files and I'll try it.
One guy several months ago had drawings so large they corrupted after a certain file size, his work was unrecoverable.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
