AutoSketch
Printing on 24 x 36 format
3 REPLIES 3
jdpettersen
733 Views, 3 Replies
When I downloaded the autosketch 10, it does not have an option for ARCH D paper. The ANSI D is a 22 x 34.  I have tried doing CUSTOM 24 x 36, but when I preview the layout, it still is not sized correctly.  All of the other SKETCH versions have had ARCH D.  My printer is an HPdesignjet 500, 36"wide rolled paper.  The pages cut smaller (22 x 34) than standard 24 x 36.  I've tried every possible change in the page setup tab.  Is there a way to download the ARCH D format????
3 REPLIES 3
Fred9002
in reply to: jdpettersen
In case you aren't doing so already, you need to set BOTH your drawing page AND your printer page  for the desired siza.
jdpettersen
I have set up the "page set up" to printing page: page size ANSI D (34 x 24).  That is where I would have found ARCH D 36 x 24 before, but not in the new version 10.  Any other place or tab you are refering to as "drawing page"?  Thank you for the help!!!!  janet
Fred9002
Hi Janet,
BTW  I  use AS9.
What I meant was 2 different settings under page setup.   One is "Size" and the other is "Printer Page"
Sincerley,
Fred
