Thank you for your detailed explanation Barry. I believe these are the
steps that I am following. The problem is that neither I nor most of the
customers who turn to us for support have the luxury of a large scale
plotter. Until V7, there was a way to output to a printer page and simply
print a full scale portion of the pattern or the multi-page group of tiles
to reassemble. I don't believe that V7 has this option. I would love to
find out that I am wrong. Lauraline
"Barry Higginbottom" wrote in message
news:56D6A6EB81E02B3ABEEAE9E4ED950F2D@in.WebX.maYIadrTaRb...
| Lauraline
| If your drawing extents doesn't print on a single page then either the
| drawing is larger than the printer page or you have selected the wrong
| drawing page size.
| There are two page sizes in use here.
| The drawing sheet size and the printer page size.
| For example I often draw on A1 page size at a scale of 1:50
| If I want a quick print for filing I will print "Fitted to Printer Page"
| "Extents", the printer page being A4 loaded in my laser printer.
| If I want an accurate scaled drawing I would then print "Scaled" "Page
View"
| to my large format plotter.
| All these settings are available from "Print Preview", a good place to
| start.
| You need to ensure that your page setup is correct, if you are producing
| drawings at 1:1 scale that you want to print to scale on an A4 printer
then
| you need to make sure that both the drawing page and the printer page
match.
| You will then be able to print your drawing accurately.
| Incidentally, I use A4 'cause I'm in the UK, in the US you'll need to
| substitute your own page sizes.
| Hope that helps.
| Barry
| "Lauraline Grosenick" wrote in message
| news:6F10234BE10EF54E759BFAAC9C0BBF25@in.WebX.maYIadrTaRb...
| > I am having difficulty again printing apparel patterns in full scale.
| This
| > was the very first problem that I found with R7. At the time, it could
be
| > corrected by tiling the individual pattern pieces separately.
| > In troubleshooting for a customer, I discovered that I could only get a
| > print to page view and even that didn't print the extent view on the
| single
| > page. What am I missing here? Does anyone else relate to this problem
or
| > have any suggestions?
| > Perplexed - Lauraline
