Hi Mr Packer
See attached pdf file I printed a e size title block on a 3x3 tile pattern. Is this what you want a large print printed 1:1 on a tiled page output 11x17 size pages?
In order to eliminate the printer driver/window version try dowloading the cutepdf print driver, then setup you drawing to print as you do but print to pdf file and then you can always print the pdf file to your epson printer.
Try printing to pdf, and print the pdf I attached and see if that gives you what you want? Please post back if you need more help.
Regards
Jason
Regards
Jason
