AutoSketch
Point of Origin...?
126 Views, 7 Replies
03-14-2000 10:53 PM
hi all,
I am trying to create a lanscape drawing that has an origin of the real
world lat. lon., is this possible in AutoSketch? The plot plan was easy,
but I would like to make the origin lattitude/longitude accurate so I can
drop points off a GPS. {Oh, I have AS R5}. Thanks in advance.
*Selzer, Gerhard
Post 2 of 8
Re: Point of Origin...?
12-15-2001 02:15 AM in reply to: *kb
kb,
Must admit that I don't quite understand the question.
Is what you are trying to accomplish something similar as per enclosed
sample?
http://www.lib.utexas.edu/maps/middle_east_and_asia/mazar-i-sharif_85.jpg
Gerhard
BTW, great job opportunities for landscape architects over there.
kb wrote:
> hi all,
Re:
12-17-2001 06:46 AM in reply to: *kb
Well, not quite that elaborate...nor that far away...
I would like to make the origin (latitude, longitude) ie (45.mmm.sss,
52.mmm.sss) or something like that... What I am really looking for is an
easy way to drop points on a "plot plan" {locate a pond and it's watershed
on my property}. If I could set the origin to the actual "earth" position,
it will be an easy matter to locate points using GPS coordinates.
Ground measurements are next to impossible due to "geographic features", ie
hills, trees, brush,...
If I am way off base... please let me know or if there is a better way to do
this.... Thanks again for your help
"Gerhard Selzer" wrote in message
news:3C1B9354.1598E03C@bellsouth.net...
> kb,
> sample?
> Gerhard
> kb wrote:
> > hi all,
easy,
can
*Jackson, Paul
Post 4 of 8
Re:
12-17-2001 08:39 AM in reply to: *kb
Hello KB
You can change the origin on your drawing from DrawingOptions > Scale.
However this is in sheet coordinates therefore you will need to divide your
figures by whatever your scale is.
Place a known coordinate in East and North ETC... in the boxes both divided
by the scale and as negative values.
To insert points use absolute coordinates as X and Y coordinates.
Paul Jackson
*Selzer, Gerhard
Post 5 of 8
Re:
12-17-2001 10:11 AM in reply to: *kb
KB,
Paul, the old pro, obviously solved the problem.
On the other had, faced with a similar problem in our area,
I would contact the Palm Beach County tax office with the
property ID number and order the latest aerial map on a disk
zoomed in to a proper scale.
(Maybe these days, I might need FBI clearance first.)
Would that not work as an appropriate reference basis for
additional info you might want to add?
Gerhard
> > kb,
> > sample?
> > Gerhard
> > kb wrote:
> > > hi all,
> easy,
> can
*Jackson, Paul
Post 6 of 8
Re:
12-18-2001 08:49 AM in reply to: *kb
Hello Gerhard
A few of our local authorities here in West Oz do what you have stated with
AutoSketch, bringing in aerial maps to check the roads and drawings.
Probably to track rogue Crocks and Koalas before they get into residential
areas.
Paul
news:3C1EA5B6.8C32F2F9@bellsouth.net...
> KB,
> Gerhard
an
watershed
position,
ie
to do
> > > kb,
> > > sample?
> > > Gerhard
> > > kb wrote:
> > > > hi all,
real
> > easy,
I
> > can
*Selzer, Gerhard
Post 7 of 8
Re:
12-18-2001 12:24 PM in reply to: *kb
Paul,
I did not talk about the other aerial maps the Chamber of Commerce
uses to check daily tourist traffic at local bars & restaurants.
I meant the other stuff were it is being verified if any trees have
been removed, any pond filled in or any shed or house addition has
been added without a permit since last year's property assessment.
Are you still using old issues of National Geographic as you data
base?
Gerhard
Paul Jackson wrote:
> Hello Gerhard
> areas.
> Paul
> > KB,
> > Gerhard
> an
> watershed
> position,
> ie
> to do
> > > > kb,
> > > > sample?
> > > > Gerhard
> > > > kb wrote:
> > > > > hi all,
> real
> > > easy,
> I
> > > can
*Jackson, Paul
Post 8 of 8
Re:
12-19-2001 09:02 AM in reply to: *kb
Yo
My maps are what Moses used when he built the arc ?
PJ
news:3C201686.FA8AAB4F@bellsouth.net...
> Paul,
> base?
> Gerhard
> Paul Jackson wrote:
> > Hello Gerhard
with
residential
> > areas.
> > Paul
> > > KB,
> > > Gerhard
(45.mmm.sss,
is
> > an
> > watershed
> > position,
features",
> > ie
way
> > to do
> > > > > kb,
enclosed
> > > > > sample?
> > > > > Gerhard
> > > > > kb wrote:
> > > > > > hi all,
the
> > real
was
> > > > easy,
so
> > I
> > > > can
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
