The only sensitivity settings for the mouse that I know about are in
Windows, they're global.
Start>ControlPanel d-click Mouse icon. Check the hardware tab for
HID-compliance, check Properties for that, make sure you have the latest
driver, blahblah. Then check the Wheel tab for the proper settings. If
you change anything, don't forget to click Apply.
If that doesn't do it, I'm tapped.
_h
gmeltd wrote:
> I've just upgraded from Autosketch v8 to v9. When panning by pressing the mouse centre wheel and moving the mouse, the movement of the image is violent and uncontrolled. It was not like that with v8. Is there a sensitivity setting that can be adjusted somewhere?
> Edited by: gmeltd on Feb 16, 2010 10:29 AM
