I have opened the .dxf in AutoCAD 2008 and all the annotation has been done
in Paper Space....a bad practice in my opinion. The text ranges in size
from .125 to .2 and seeing the drawing is initiated from the States, it
could be in inches but as I work in the real world with metric
(millimetres), the text could be .125mm to .2mm which is microscopic.
You will need to ask your draftsperson to re-annotate in Model Space or
he/she can export all the information from Paper Space to Model Space.
AutoSketch does not support Paper Space. Screen capture attached.
Ric Norris.
wrote in message news:5885296@discussion.autodesk.com...
Nope,
I've tried DXF...AutoCAD 2004 and an AutoCAD 2004 created by doing a Save
As... with TurboCAD. There's something peculiar about this drawing that
makes the text disappear whenever I open the file using AutoSketch.
It's odd because the Text does appear in the Preview Window and it also
shows up using virtually every DWG or DXF viewer I've come across.
Here's the DXF version, it does the same doggone thing 😞
