AutoSketch
Member
amigdal
Message 1 of 6 (1,018 Views)
Older .skf files
1018 Views, 5 Replies
05-12-2010 01:33 PM
I have a number of .skf files dating from 2003-2004 that I need to access, but I have been unable to find a viewer for them or affirmation that a current version of Autosketch would be able to open them. Any suggestions would be welcome.... Thanks!
Distinguished Contributor
000jdi
Message 2 of 6 (1,018 Views)
Re: Older .skf files
05-13-2010 02:45 AM in reply to: amigdal
Hi, What version of AS were these files created in? 2003-2004 was around the AS9 time. There is no viewer for these files. I would think AS 9 or 10 would be able to open these files. If it is necessary you could have someone try 1 file for you and then you could decided how to proceed. Are you in need of the opening the file and reading only like printing to pdf or do you need to open and export as dxf,dwg?
Regards
Jason
Regards
Jason
Member
amigdal
Message 3 of 6 (1,018 Views)
05-13-2010 09:12 AM in reply to: amigdal
Hi Jason, thanks for responding. As it happens, I have copies of the program files (but not the installation disk) for AS, and the version for the Sketch.exe file appears to be 8.0.23.0 - so I'm guessing version 8? If I knew someone with the program installed, I would happily ask them to open one of these files just to be sure before we purchased the software.
We do not need to do anything other than view the files and possibly print to pdf.
StevenMac
Message 4 of 6 (1,018 Views)
05-15-2010 11:10 PM in reply to: amigdal
Just attach a non-commercially sensitive file to your reply and I can check it with AS10.
Member
amigdal
Message 5 of 6 (1,018 Views)
05-16-2010 10:53 AM in reply to: amigdal
Thank you - I finally got support at Autodesk to do just that, and they confirmed that AS10 was able to open the test file that I sent them.
Member
slang115
Message 6 of 6 (416 Views)
04-21-2011 12:55 PM in reply to: amigdal
DO YOU HAVE AUTOSKETCH AND WOULD YOU BE WILLING TO CONVERT SOME SKF TO DWG FILES FOR ME?! PLEASE
STEVE.LANG@ASKTECHNOLOGIES.COM
