AutoSketch
Newbie needs help
2 REPLIES 2
738 Views, 2 Replies
Newbie needs help
New to Autosketch 9 and would like to import a pdf file (a dwg) into Autosketch.
In fact, how do I import any variety file into Autosketch?
Can somebody help?
Thanks, John
2 REPLIES 2
Kevin.Hutch
I too have found a need for this, but alas so far only found a long way round.
1. Open the PDF drawing or photo select the required area ctrl C to copy.
2. Paste it (ctrl V) to a file opened in a graphics package "Paint" or "GIMP 2".
3. Crop and/or modify as required.
4. Save the file as a GIF file (I have found GIF the most effective for line drawings).
5. Open Autosketch and insert drawing as a separate layer.
6. Lock the layer and on another layer trace the outline or add the required additions.
If it is a complex original and sections are not required I "block out" with a white rectangle.
Kevin H
Kevin Hutch
Be part of the solution not part of the problem
(61) 4 0887 1538
thixoman
the file formats are incompatible, ,   like opening a word document in photoshop,
for years, i have been using scanvector,  I scan the drawing, (a raster image) and save as needed, and then open the file in SV an exportas a VECTOR/ dxf.  Open drawing program an insert into or  as I have had to do more often than not, open the dxf file an do a little "clean up", then save it and re-open / import to main drawing.
