Can I set up a drawing to print various views on the same page? E.g. Plan view at center top of page, along with a one or two section details arranged at the bottom of the page? If so, how?
You will need all the views needed.
Create a new page setup for your printer.
Planning ahead, if you have dimensions on the drawings, they will be changed in the process unless the dimension is 'exploded'. Do this by selecting the 'dimension', then use the explode tool.
Now select the whole drawing, perhaps group it too. Now use the handles to drag it to a smaller size to be used on the single page. Copy the selected drawing (Ctrl C), click on the new page and Paste (Ctrl V). Drag the drawing to a location you like, and repeat with other drawings you want on the sinlge page.
I use Dave's method of copy/paste to add views onto one page. There's another method detailed at the bottom here
http://forums.autodesk.com/t5/AutoSketch/Dimensioned-details/m-p/2637647#M11508
