Hi Jim
See pic, basically you need to turn on the content librarian, right click in a existing tool bar area. Check content librarian.
The item 1 in the picture opens the explorer, where you can see all the libraries already with the program, and you can also add a new library here.
Item 2 is the buttons to create, insert, edit fields of symbols.
Symbols can be created by selecting the items you want, click the create symbol button, and follow the dialogs.
You can change a symbol and do the same as above to create and use the smae name and the symbol will be updated in the library.
You can drag the symbols in and scale or rotate them as needed, i would do the scaling in the properties box, or with the scale tool.
The tool bar that activates at the top when you select a symbols will scale or rotate all symbols based on the numbers in this toolbar so be careful.
Try that and ask more questions.
Regards
Jason
Regards
Jason
