AutoSketch
Missing Use As New Template checkbox
1 REPLY 1
Quiltforever
428 Views, 1 Reply
Trying to create new default template.  Older version had a check box that indicated Use Created Entites Above All Others and in installing Autosketch 10 that check box has mysteriously disappeared.  Was previously underneath the list of templates available.  Also, pop up cannot be resized and appears to be cut off.
1 REPLY 1
Dave_K4
in reply to: Quiltforever
Looking at your screen shot, you'd need to click on the button to organize, then on the next window Add, then you will get the dialog box with the option you are watchiing for.
