AutoSketch
Library block with wheelchair?
2 REPLIES 2
417 Views, 2 Replies
Is there a symbol library with a plan view of a wheelchair anywhere? I've had a look and can't find any.
2 REPLIES 2
Gadget,
You probably already found a symbol for a plan view of a wheelchair, but here is a great site for many symbols. http://cben.net/ You will need to do some work, changing over from a dwg to a autosketch symbol. Check out on the site, on the left, A.D.A. guidlines, and do some searching, you will find a plan view. Hope this helps.
Treeguy
Thanks for the reply: I ended up making one up myself - the ones I found were a different style and just didn't look in keeping with the rest of the plans.
