I just purchased a very inexpensive copy of Autosketch 9. I used to use Autocad release 10. I was able to draw a box around several lines and type polyedit, then join. How is this achieve using autosketch? I see where it has the ability to join entities but I can only select one line at a time and they never join.
TIA,
HI
Use the trim join tool hold down ctrl then select one line and all connected lines will join together.
or edit trim join from menus
Regards
Jason
