Hi Don,
I don't have an answer, but I have the same problem. The most common SHX
file that "I need" is ARCHQUICK. Usually, I just select a different SHX
file that I do have and it seems to substitute OK. Of course, not knowing
what ARCHQUICK is, it would be hard for me to figure out what I'm not
getting.
Good Luck!
Scott
Don Weiner wrote:
> I have a whole series of drawings that use SHX files that I don't have,
> such as ATOBL.SHX, HELVITE.SHX and X-OPTA1D.SHX. When I open the
> drawings, I have to cancel out of the dialog box, which may show up many
> times for each SHX file, in the process of opening one drawing. What am
> I not getting? The drawings were created with Autocad (don't know what
> release, most likely recent). Are these fonts, special symbols or
> something else?
> Thanx,
> Don Weiner, PE, RCDD
