AutoSketch
*Weiner, Don
Message 1 of 8 (278 Views)
Help with drawing clouds
278 Views, 7 Replies
12-14-2003 06:50 AM
When I revise a drawing, the changes must be identified by drawing a
'cloud' around them. I'm presently using a combination of using the
cloud symbol creating a square cloud symbol and changing the scale, but
that only works for changes similarly shaped and sized. Other than
drawing a bunch of interconnected arcs, does anybody have a better way
to draw clouds?
Thanx,
Don W
*Selzer, Gerhard
Message 2 of 8 (278 Views)
Re: Help with drawing clouds
12-14-2003 06:50 AM in reply to: *Weiner, Don
Thanks Don,
Never knew that the cloud symbol existed.
Always wondered how my engineers had the time
to do all those little arcs.
Solved the mystery.
Put symbol on a my letter size sheet which is
set at the scale of 1/2"=1'-0", chose scale
factor 10, exploded it, highlighted it and used
the handles to drag it to any size I wanted.
Could rubber-stamp it where I wanted to or copy
and paste it.
Hope you have the same fun I had.
Gerhard
> to draw clouds?
> Thanx,
> Don W
*Pike, B
Drawing clouds is easy - just draw an irregular polygon with the bulge
factor set to about 0.4 (adjust this to suit yourself) anti-clockwise around
the items(s) you wish "clouded". Each cloud is different and suits the area
you wish enclosed.
The markers for the cloud, if you want them, can be added separately, and
can be a symbol with a database field.
Best of luck
B Pike
"Don Weiner" wrote in message
news:3B683996.95D3E7A1@mailbox.bellatlantic.net...
> to draw clouds?
> Thanx,
> Don W
*Rafuse, L.
There are very few things I like about AutoCAD. The AutoCAD revision cloud
feature is one of the things I do like. I wish AutoSketch had this
feature. I currently use the Sketch Polyline tool and circle my changes.
Maybe version 8 will have a revision cloud tool...and fix the version 7
bugs....and add macro's back in... and fix the prints issues....
Len Rafuse
Vision Engineering
> to draw clouds?
> Thanx,
> Don W
*Selzer, Gerhard
Message 5 of 8 (278 Views)
Re:
Len,
In my previously related post, I used the AutoSketch
"Business Graphics" cloud symbol.
Did I miss your point?
Gerhard
> Len Rafuse
> Vision Engineering
> > to draw clouds?
> > Thanx,
> > Don W
*Weiner, Don
Re:
B Pike,
Thanx. That works great.
Don Weiner
> you wish enclosed.
> Best of luck
> B Pike
> > to draw clouds?
> > Thanx,
> > Don W
*Rafuse, L.
Re:
This works great.
Len Rafuse
Vision Engineering
> you wish enclosed.
> Best of luck
> B Pike
> > to draw clouds?
> > Thanx,
> > Don W
*Rafuse, L.
Message 8 of 8 (278 Views)
Re:
My changes are often oddly shaped so it doesn't make sense to use that symbol.
Len Rafuse
Vision Engineering
Gerhard Selzer wrote:
> Len,
> Gerhard
> > Len Rafuse
> > Vision Engineering
> > > to draw clouds?
> > > Thanx,
> > > Don W
