AutoSketch
HELP! circular array
3 REPLIES 3
wcottr
2593 Views, 3 Replies
I am trying to create a circular array of 3/8" diameter holes. There are 32 holes in the array arranged on a circle diameter of 20". I KNOW  this can be done but I sure can't figure out how. Can one of you folks help me? I am using Autosketch 9. Thanks for the help!
plain ol Bill
3 REPLIES 3
in reply to: wcottr
I use AS 10.
1. Draw a circle of radius 10"
2. Draw your first 3/8's hole on that circle.
2a. Press Q to turn on quadrant snap so you can draw the 3/8's at a fixed point (12 o'clock, 3, 6, 9) or
2b. Draw a straight line from the centre of the r10" circle at a specific angle
http://i20.photobucket.com/albums/b238/-Bastard_Child-/c78e44df.jpg
3. Select the 3/8's circle to turn on the circular array tool
4. Divide 360 degrees by your interval (=11.25 degrees)
5. Enter as follows: http://i20.photobucket.com/albums/b238/-Bastard_Child-/6637d388.jpg
5a. If we do 32 copies we'll have two circles on top of each other at the start
5b. If that tick box is ticked it'll dump circles on top of each other
6. Press OK and pick the centre of the r10 as your base (keyboard shortcut for centre snap = C)
draw a straight line at a specific angle
wcottr
Thanks for the reply - that worked. I had done it before but it had been too long for this old memory to figure out what the heck I had done.
in reply to: wcottr
That's ok, if you have any more questions keep them coming.
What's really frightening is the amount of stuff you don't realise you've forgotten!
