AutoSketch
Hello AutoSketch help people
3 REPLIES 3
277 Views, 3 Replies
I still have this problem aligning a group of objects to the grid after copying and pasting to another sheet. I have tried everything suggested with no success. Is there someone who I can communicate with via email on a one to one basis to work through this?
Regards
Paul
3 REPLIES 3
Paul
Try this
after you have pasted objects to a new
sheet
-Select the group of objects you want to
move.
-Select the translate tool (
Edit>Transform>translate)
-Identify 1 point that was aligned to the grid of
the old sheet & you want aligned to the grid of the new (probably
an endpoint of a line)
-Type 'E' for endpoint snap, or another appropriate
snap for the point identified ,DON'T use 'G' (grid snap)
just yet,snap to that point
-Now that you have the selection attatched to your
mouse movement. Type 'G' for grid snap and pick a grid point on your drawing.
The group of objects should now be
aligned.
Regs
Graeme
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Regards
Paul
Thanks Graeme
This works well.
Best regards
Paul
Hello
Two ways
1    Right click on the about point,
reposition it and then drag it to a new position.
2    Use Transform Translate and
follow the prompts in the bottom left corner.
Bot of the above can be used with lock mode for
vertical (V) or horizontal (H).
Paul J
I
Regards
Paul
