AutoSketch
Hatching=None or Filling=White => filled with Black
5 REPLIES 5
tomte-da
1218 Views, 5 Replies
after having filled
two chambers and
a pipe between
with red color I took a gif picture for an animation.
Then I need to empty the pipe and take the next gif for the animation.
Because Polylines are much too thick I drew a multiline rectangle over the portion to be emptied.
Into this rectangle I try to fill either nothing or white, but in both cases Black is filled in instead.
How can I optically "empty" that rectangle?
Only sketching quality is needed for the animation.
5 REPLIES 5
StevenMac
in reply to: tomte-da
As you found out you can't have white, but you can have another shape inside a shape.
This will allow you to control what is shaded.
Fred9002
To make white fill be white, go to "View"->"Options"->"If same as page color" and uncheck "Invert pattern"
tomte-da
in reply to: Fred9002
Great, Fred9002, i will try that ... Thanks! tomte
StevenMac
Fred that is brilliant!
Fred9002
in reply to: StevenMac
Thanks.  Most of these things were head-scratchers for me sometime back and it's nice to be able to try to help.
