Hi all,
I am trying to create a global report across multiple .skf drawings.
I have created a template which contains the local report i desire with a ready made global report.
I have prepared a set of symbols with field entries for a number of temperature sensors.
I've created two drawings (Draw A & Draw B) using my template, which i then add symbols too.
Draw A contains a single Outside Air Temperture Sensor symbol.
Draw B contains two Room Temperature Sensor symbols.
I select 'Database' in Draw A and then 'Report' and select the 'Global Commissiong Report' from the list and press the 'Report' button.
Autosketch retrives the information from only one of the drawings, i have managed to get global reporting to work before but seem to be having trouble doing so with a prepared template.
Can anyone shed some light on where i might be going wrong?
I want to get a report that shows information from both drawings, like this:-
Outside Air Temperature Sensor (from Draw A)
Room 001 Temperature Sensor No.1 (from Draw B)
Room 001 Temperature Sensor No.2 (from Draw B)
I have attached a .zip file containing my template, Draw A and Draw B and the report files for both drawings.
Any help would be fantastic.
Cheers
Malcolm
