TrippSND
Check to see also that your path statement in your autoexec.bat file is
less than 127? 128? characters long.
TrippSND wrote:
> You are a genius!! It worked!! As far as the upgrade issue, I could
> just delete the .dll files from the main AS folder and proceed with
> the upgrade?
Melissa Leggee
Autodesk Product Support, Americas
WW Support and Services, Autodesk
Discussion Q & A: <>>
