AutoSketch
Editing polylines
1 REPLY 1
394 Views, 1 Reply
Editing polylines
Is there a way I can change the length & angle of a poly line like I can do with basic lines?  Example:  If I draw a poly line that isn't straight or long enough, is there a box I can just enter a value to change the polyline?
1 REPLY 1
Not as far as I'm aware.
If you hold down the polyline icon in the menu, you get access to the 'polyline segment'.
Otherwise if you need specific shapes you could draw what you want with regular sketch lines and trace over the top with your poly.
