The nice thing about standards is that you can have so many of them. If I draw a single hairline circle I cannot (yet) export it from AS10 to produce a .DXF file which AS2.1 can read.
The .dxf files which AS2.1 produces can be imported into all sorts of other programs - I use 2.1 to produce hairline drawings that DesignSpark can use to turn into printed circuit Gerbers - but I can't get a .dxf from AS10 that I can read with 2.1.
Anyone know of an intermediate program? or of one that will read modern AD.dxf files and export ones which 2.1 will read?
Mike Ross
Solved by ameramameramameram. Go to Solution.
Solved by thixoman. Go to Solution.
Sorry - missed your "what do you want to do with it?" query.
I need it in either a .DXF or a .SKD format so I can open and edit it in AS2.1.
Can do?
Work of significant genius!
Are you able to share or sell the secret? Or do I just pester you whenever needed?
Thanks a bunch.
Mike
Mike and ALL
If I can be of assistance to anyone in the area, don't hesitate to email or post.
