AutoSketch
New Member
0 Kudos
Post 1 of 6
DWG to SKF conversion
692 Views, 5 Replies
01-07-2014 10:58 AM
Hello experts,
I have AutoSketch® 10 tool. I recived a drawing in .dwg format from my customer. I am trying to open with autosketch and getting error message.
Below is the procedure which i used.
File>Open>Selected file type as *.DWG>Selected my file>clicked open
Error message: Error processing <File Path>.dwg
When clicked OK>Unkown file type pop-up window opens.
Then selected AutoCAD drawing file and clicked OK
Any help is appriciated.
Pavan
1,588 Kudos
Post 2 of 6
Re: DWG to SKF conversion
01-10-2014 03:50 AM in reply to: varmabpk
What format DWG file? It needs to be as old as possible and not a current DWG format.
Ask you sender to help.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
2 Kudos
Post 3 of 6
03-25-2014 11:53 AM in reply to: varmabpk
hi
send me the file
Al crosby_a@hotmail.com
Active Member
0 Kudos
Post 4 of 6
03-26-2014 01:21 PM in reply to: varmabpk
DWGtrue view can be used to convert dwg files to earlier versions and opened in Autosketch 9. I do it all the time. Some files I get I have to convert to autocad 2000 some to 2004 and some I can get away with 2007.
DWGture view is free from autodesk.
Active Contributor
2 Kudos
Post 5 of 6
03-26-2014 02:37 PM in reply to: askotlen
Granted, that is true, , ,  however, there are some of us who, for reasons unknown, still have and use programs going back to Windows 3.1.1,  otherwise known as 'back in the day'. Over the last 2 decades, thru this Autodesk site, I have, for NO CHARGE,  redered or converterd over 1500 files in all configs and O/S, even old school intergraph / microstation and beyond. The first DOS cad program I used was Autosketch 1, then Autosketch 2.1 WINDOWS  and then Generic ( geriatric ) CAD 6, , ,  still have all of them. The program of which you speak of in 2014 format only works on systems using  newer operating systems, , ,  of the 8  CAD stations I curerntly run, 2 are still using DOS 5, DOS 6.1 & windows 3.1.1. and Windows 95. Its mostly for us old farts that need to have the old files brought back to life. My plotters were HP 7550, printer was an HP500C, then the big jump to Draftmaster II, , ,
Anyway, thats my story, and it works. :smileyhappy:
Active Contributor
2 Kudos
Post 6 of 6
04-09-2014 05:21 PM in reply to: varmabpk
Hi still waiting for your file to convert
