AutoSketch
*Workman, Jim
Message 1 of 3 (258 Views)
Drawing recovery
258 Views, 2 Replies
11-24-1999 06:26 PM
I am running Autosketch 6 and had a computer crash. When I try to load
the drawing that was being worked on, I get the message "Unexpected file
format" which will not allow me to work on that drawing. Is there a way
to recover the drawing as in AutoCAD?
*Jackson, Paul
Message 2 of 3 (258 Views)
Re: Drawing recovery
11-24-1999 10:26 PM in reply to: *Workman, Jim
Hello Jim
If, under Tools>DrawingOptions>File you had create backup ticked, there will
be a BAK file of your previous save. To access BAK files go to the Open
File box and type in *.BAK as the file name and a list of these files will
appear, and then see if you can open the file.
If you did not have this box ticked, DO IT NOW.
When a crash occurs V6 also sometimes makes an RCV file which it saves in
the AutoSketch installation directory, and once again go to open and find
where AutoSketch is loaded and type in *.RCV
This type of problem usually occurs when a file is saved to a disk with no
free space available, and it cannot finish saving and hence the file is
trashed. If you were working from a Floppy, DON'T, as floppy drives are
disasters waiting to happen.
Regards
Paul Jackson
Jim Workman wrote in message <383C9E71.70A9F337@skynet.ca>...
*Support], Keith Sibbert [Autodesk
Message 3 of 3 (258 Views)
11-25-1999 01:57 AM in reply to: *Workman, Jim
Jim,
In addition to Paul's suggestions, you might also try File>Merge and see if
the file will merge into a blank drawing.
Keith Sibbert
PSG Product Support, Americas
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
