Thanks John, Graeme and JKL,
Had hoped hoped to use my standard Swis721 BT that I use
now on all my drawings because it matched the Chartpak
Helvetica rub-ons I used on the drafting board.
Tried Aerial black, not a bad match even though not as
crisp.
Will have to get used to it but for dimensions only if
I ever get over my basic hang-up about using automatic
dimensioning.
Gerhard, 6.01
John Nolte wrote:
> Gerhard:
> You can select any of the available fonts, some of which are bold, in the
> "Format Dimension " box, lable tab. It comes up on the edit bar as soon as
> you select the dimension tool. Arial Black, for instance, is comparatively
> bolder than Arial. Check "Save as default" to keep the font current.
> John
> "Gerhard Selzer" wrote in message
> news:3C15617B.BCE25214@bellsouth.net...
> > Hello,
> > Can one set the dimension numbers to a "bold" type
> > at the start or is "explode" afterwards the only way?
> > Gerhard
