HI John
The detail view option in AutoSketch is nice but incomplete as designed , it seems you can only create views that are images and they update as you turn layers on/off and add dimensions. It was a nice tool in its day but since its hasen't been updated in many,many years.
Another work around
Create your geometry save file example "mainfile.skf"
Save to another file name. "mainfile_details.skf"
In the 2nd file you save as a copy of the first add the dimension you would want to see in a detail view.
Then create the detail views you want.
You can then copy the detail views and paste as linked into your main file.
If they are inserted as linked they will update if you need to change your details.
This keeps the detail views that you can scale and the dimension separate so you can control a little better.
Disadvantages you have 2 files to keep up with. ie you would have to modify the geometry and paste it to the 2nd file if you need to change.
Advantage you have detail views you can control with the detail view tools of AutoSketch.
Regards Jason
Edited by: 000jdi on Feb 27, 2010 1:37 PM
Regards
Jason
