...and of course, our old friend, the Working Point. Use that with Translate and
you can move anything anywhere anywhichway.
Harvey
Paul Jackson wrote:
> Two ways
> 1. Use the Transform>Translate command
> 2. Select the object. Right click on the about point and from the menu
> select "Move AboutPoint". Snap the point to your object with the left mouse
> button and then use the left button again to drag into position using
> whatever snaps are necessary.
> Paul
> wrote in message news:4954647@discussion.autodesk.com...
> What is the best way to copy an element from a specific point on it to a
> specific point on another element? For example, I want to select a triangle
> and copy it from the midpoint of one of the sides to an endpoint of a
> different element. I know the copy command is now rubber stamp, but rubber
> stamp seems to select its own reference point to copy from. Thanks.
