Hello --
Using the DXF format to copy from TCAD to QC7 (and I suppose to
AS6 or AS7) works pretty well -- *but* please delete any
"Construction Lines" from the TCAD drawing before converting.
These lines if converted can cause the most frustrating and
obscure errors to appear in your QC (and probably also AS) files;
quite often, after a long period of use in the QC world.
Take care,
Will
Paul Jackson wrote:
> Hello AutoSketch can import DWG and DXF files. However line
> styles and symbols may change, so don't expect 100%, probably
> 80%. This also depends on TurboCAD export configuration and
> computability. Paul Jackson Fugg wrote in message ... >Is it
> possible to import existing Turbocad Files (TCW)into Autosketch
> Release 7?
