AutoSketch
Convert SKD files to DWG
8 REPLIES 8
Message 1 of 9
5877 Views, 8 Replies
I would like to know if I purchase AutoSketch 10, can I open an SKD file and save it as a DWG so it can be edited with AutoCAD?
8 REPLIES 8
Message 2 of 9
I've sent you my contact details in PM
Message 3 of 9
Hi Can you help me with my question. Thanks. Mike Pearson Eaton, Electrical Sector 5050 Mainway P. O. Box 5040, Station A Burlington, Ontario, L7L 5Z1 Tel: 905 631-4165
Message 4 of 9
I'm sorry - was there an answer here?
Message 5 of 9
Mike you need to find my email address in the private message area.
Look for the envelope icon, up the top-right of the forum
MrWeb I'll send you one too.
Message 6 of 9
Hi!
Same problem here - one of our clients cooperates with Autosketch users, and he receives files in .SKD format. Same question: If he buys Autosketch 10 - will he be able to open .SKD files and save them as .DWG so he can work on them in his AutoCAD?
Trial of Autosketch is not available, right? Nothing have changed here?
Thanks in advance.
Staszek Ciesielski
Message 7 of 9
Well according to StevenMac the answer to this is YES. This does seem to be one of the world’s best kept secrets for some reason.
IF you still have your old version of Autosketch  which produced the .SKD files on an XP PC, you can go to File-Export DXF-save.  The DXF format should open in other programs.
Message 8 of 9
Hello Stasze Yes you can save a skd file as a .dwg in AutoSketch 10 and no there is no trial version. I just got back from holidays, sorry for the late response. Hope this helps. Mike Pearson Eaton, Electrical Sector 5050 Mainway P. O. Box 5040, Station A Burlington, Ontario, L7L 5Z1 Tel: 905 631-4165
Message 9 of 9
The version of AutoSketch we have does not support export to DXF. That was the first thing I thought of, I do not what versions does support the export to dxf. I know AutoSketch 10 can save as .dwg. Mike Pearson Eaton, Electrical Sector 5050 Mainway P. O. Box 5040, Station A Burlington, Ontario, L7L 5Z1 Tel: 905 631-4165
