I have been able to successfully convert my old drawings from Autosketch Release 5 to .DWG. The purpose of this is to open them into Corel Technical.
The issue i am having is when i open the drawing in Corel, all that shows up is the text from the original autosketch drawing. Any tables or Photos that were inserted into the Autosketch drawing disappear. Is there any way to conver the file to .DWG and keep all the componenets of the original drawing? Any help would be great!
Thank you
Hello
Here is a brief description of the problem we have when attempting to convert some Autosketch.skf files into an editable Autocad.dwg format.
It is apparent that some Autosketch files (100+) have been apparently produced on the earlier Autosketch ver. 3 of the Autodesksoftware on different Windows platforms and for somereason, these will not convert to editable AutoCad Dwg files.
We currently use Autosketch 10, which will not `Save as’ or convert .skf files into Acad compatible dxf or dwg files.(see attached .doc file)
(Autosketch is apparently no longer supported by Autodesk ?)
I have also attached a zipped up typical problematic Test.skf file. and also some correspondence from Symetri (IT support-see below) which details our attempts to source a fix.
It would be appreciated if you could attempt to provide a workable solution to this frustrating file conversion problem !
hi
send me a file or 2 an will give u option
will have to convert most if not all of them from original Ver to current program to give you DWG
crosby_a@hotmail.com
